full_mosey
May 21, 2013Explorer
Jim;
Could the Amp bouncing be related to the bubbling? IMHO, bubbling is not normal.
It is odd that you are the only AGM owner that has reported hearing any bubbling unless performing recovery charging on known problem AGMs. Are you sure your batteries are healthy and the valves have not been compromised?
There was a poster that reported chalking on his AGMs. It turned that Lifeline knew about a few AGMs that had bad valves and they shipped new AGMs at no charge. You might want to call Deka.
What Amp acceptance reading indicates fully charged to you? The only time I see zero Amps is with my SC-1200A 2/8/12A Schumacher portable charger because it floats with an on-off method every few seconds.
HTH;
John
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
