MEXICOWANDERER's avatar
Jan 21, 2018
An Image Of A Properly Designed High Amp Alternator
  • Note the 1/4" aluminum plate bolted onto the rear of this 7074 Ford 100 amp alternator
  • The plate has 12 rectifiers (diodes)
  • These are negative rectifiers
  • Unseen within the case are 12 positive rectifiers. 24 total
  • The original had six total rectifiers 3+3
  • Notice the rear bearing. It has a nipple on the end to hold more grease
  • Heads up performance versus a Nippondenso hairpin alternator leaves this one in the dust
  • Yet the rectifiers in the Ford are light years more durable than those in the Nippondenso
  • There are few "free lunches" in the alternator design dept
  • I have redesigned and built more than two dozen special purpose alternators
  • I am all too familiar with what can and cannot be done mechanically, electrically, and durbility-wise
  • Looks good. Two of those bolted on to the Hemi and a 3000 watt psw inverter, I could run my trailer air while driving - no more climbing into an oven when stopping for the night.
  • It serves as an example. It is a 160 amp alternator.
    Two shortcomings with the Ford 70-100 amp alternator series
    • Very short brushes. Part of the brush holder
    • Original has a 6203 front (DE) bearing -- inferior for heavy service
    • OEM has gone to larger 6303 bearing on newer alts
    • I do not know if unit shown has an upgraded drive end frame to use the 6303 bearing.
    The two screws near the regulator plug _May Be_ for the brushes. The field connection. Insulated brushes can be connected to an A or to a B circuit voltage regulator.
    The 5/16" bat bolt on the right looks like it is insulated, making it the + bolt. The one one the left looks like a chassis negative bolt being it's not insulated from the case.
    When I was building these things, I had Saint Mary's Carbon build graphite copper brushes that were 5/32" longer than the originals. The absolute longest possible. The brush retaining pin slid across fully depressed brushes during assembly.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
