pianotuna
Feb 26, 2015Nomad III
Hi Mr. Wizard,
It is still nice that the inverter/charger chooses solar first as a power source. I can see using such a device to power my laptop which is almost always on. I'm assuming the overhead from the inverter would be supplied directly from the panels.
As it is a 30 amp pwm device it could handle up to 4 hundred watts. That would power the fridge, and still charge the battery bank between duty cycles.
I'm unlikely to switch to this as I got the fancy Magnum.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
