Gerald55
Jan 23, 2016Explorer
I should add, although I don't think it matters:
The wiring is such that the inverter is the only thing wired directly to the batteries, via 2/0 cable. The solar controller output, as well as the 12V leads for the rest of the coach, are all wired to the inverter terminals.
Circuit-wise this is all same, but I'm not sure if wiring the controller leads to the battery somehow causes more of the PWM noise to affect the inverter.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
