time2roll
Jan 24, 2016Nomad
Here is a note from Tristar:
PWM Noise: In some installations, the PWM charging may cause audible noise in certain equipment. If this occurs, the PWM can be changed to “OnOff” solar charging to reduce the noise. This requires DIP switch number 8 to be turned On. However, it is strongly recommended to try to remedy the noise problem with grounding or filtering first, because the benefits from PWM battery charging are significant.
See page 28
Unfortunately no real suggestions for grounding or filtering.
See page 28
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
