MEXICOWANDERER
Jan 27, 2016Explorer
Your inverter but not solar controller is not conducting the inverter to "Sing Along With Mitch?".
A Pie Filter is not the answer because of the size. Experiment with electrolytic capacitors across the inverter battery connections. .01 - .1 - .47 - 10 or 100 uf ought to nail it down. Caps are cheap. Just don't connect the electrolytic ones backwards. They are clearly marked.
GOOOOOOOOGLE this...
200-ampere pass-through filter.
When Xan-Ax bought out Trace I dropped the line like a hot rock.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
