grizzzman
Jan 29, 2016Explorer
Almot wrote:Salvo wrote:
A good design has all battery charging sources connected directly to the battery.
Through the Pos bus is the correct way.
Controller-> breaker-> Bus-> battery fuse ->battery.
Same for loads, same for inverter, all on the same bus.
Though, this is just for safety. The circuit remains the same, in terms of parallel connections of battery, chargers and loads. If inverter (or controller?) is poorly shielded and PWM pulses are causing this noise, I don't know whether this "better" layout with help with noise. Going MPPT will help ;)
So...... are you saying that MPPT does not use PWM during Absorb???? How is it that it dosent use PWM????
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
