Salvo
Jan 29, 2016Explorer
You're not making any sense to me.
Say you have 3 battery charging sources: alternator, converter and charge controller;
and 2 battery loads: inverter and dc power center.
All 5 (positive) cables should go independently to the fuse (or fuses) located next to the battery. Likewise the grounds should go independently to the battery chassis connection or independently to battery ground.
In other words, do not daisy chain any power cable!
Almot wrote:Salvo wrote:
A good design has all battery charging sources connected directly to the battery.
Through the Pos bus is the correct way.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
