BFL13 wrote:
Why would going to 100% take longer with lower capacity?
The amp tapering stage at constant absorption voltage takes longer now at deep cycle ~750 than it did at cycle number 200.
I assume because of increased resistance accumulated with age and slight sulfation.
It also takes less time for it to reach absorption voltage with the same amperage applied from the same AH from full, and thus reaches absorption voltage at an even lower state of charge, than with less cycles accumulated.
These are repeatable observations.
I've little doubt you will notice the same with your AGMS as they age.
