RDMueller's avatar
RDMueller
Another battery question
So many threads here about batteries and charging, I can't believe I'm starting another! Well, I've learned a ton, and actually if I was starting from scratch I know pretty much what I'd do to create a nice setup. But I'd kind of like to use some or all of what I already have. Part of it is that when I look back at our past 5 years of camping, 75-80% has been with electric hookups and when we do dry camp, it's usually only 3-4 nights. So to me it doesn't make sense to invest a bunch of money in really good batteries, solar and a top quality charger. If our camping was primarily off grid, I'd do it in a heartbeat, but since the opposite is true, I'd rather spend the money on other upgrades.
So here's what I have - the TT is brand new and came with the typical WFCO 3 stage 55 amp converter/charger. I realize that there are far better converters available and someday I'll probably upgrade, but for right now I can't see ripping out a brand new component. The battery is an Interstate group 24 that says Deep Cycle on top, but when you read the fine print, it's just another marine battery. I also have a second group 24 marine battery that is about 2 years old and in very good condition.
I realize that true deep cycle batteries would be far better - when these are ready to be replaced, I'm going to go with a pair of Trojan T105's. But for now, since I have the marine batteries, I'd like to use them. I guess though that since one is new and the other isn't, I shouldn't connect them in parallel.
I'm going to get a Honda or Yamaha 2k inverter gen, so I'll have the ability to charge, but I'd rather try to conserve as much as possible to keep gen run times to a minimum. When dry camping, we will us mainly lights and the water pump, very little if any furnace time, no TV, no inverter.
So in this situation, what would you do?
