RDMueller wrote:
One other question. I just read on one of the other threads that just the fridge 12V control panel and the CO detector will use about 30Ah per day!?!? I find that kind of hard to believe,
Does your fridge have auto-ignition or just a pilot? My old PUP just had a pilot and manual control so it used no battery power.
A combination CO & propane detector uses about 1/10 amp so ~2.4 amp hours in 24 hours. I encourage you to leave this on in all conditions.
http://www.mtiindustries.com/products.asp?cf=1&ti=0&ci=1&si=1π=1A radio even if off may take a little battery power also along with a few other things. My trailer idles at about 500 milliamps (1/2 amp) running detectors, fridge control, water heat control, radio memory etc so 12 amp/hrs per day. Your PUP should be less and certainly not 30Ah.
