RDMueller's avatar
RDMueller
Another battery question
So many threads here about batteries and charging, I can't believe I'm starting another! Well, I've learned a ton, and actually if I was starting from scratch I know pretty much what I'd do to create a nice setup. But I'd kind of like to use some or all of what I already have. Part of it is that when I look back at our past 5 years of camping, 75-80% has been with electric hookups and when we do dry camp, it's usually only 3-4 nights. So to me it doesn't make sense to invest a bunch of money in really good batteries, solar and a top quality charger. If our camping was primarily off grid, I'd do it in a heartbeat, but since the opposite is true, I'd rather spend the money on other upgrades.
So here's what I have - the TT is brand new and came with the typical WFCO 3 stage 55 amp converter/charger. I realize that there are far better converters available and someday I'll probably upgrade, but for right now I can't see ripping out a brand new component. The battery is an Interstate group 24 that says Deep Cycle on top, but when you read the fine print, it's just another marine battery. I also have a second group 24 marine battery that is about 2 years old and in very good condition.
I realize that true deep cycle batteries would be far better - when these are ready to be replaced, I'm going to go with a pair of Trojan T105's. But for now, since I have the marine batteries, I'd like to use them. I guess though that since one is new and the other isn't, I shouldn't connect them in parallel.
I'm going to get a Honda or Yamaha 2k inverter gen, so I'll have the ability to charge, but I'd rather try to conserve as much as possible to keep gen run times to a minimum. When dry camping, we will us mainly lights and the water pump, very little if any furnace time, no TV, no inverter.
So in this situation, what would you do?
  • I would do?
    Parallel the existing 2x group 24
    Honda/Yamaha 1000 (assumes no microwave when off grid)(used if possible)
    LED lamps
    30 amp IOTA with IQ controller(replaces WFCO)
    100 watt solar
    No particular order.
  • Leave one of the 24s at home on a maintenance charger except when you know you will be going off grid, then put the two in parallel for that, then leave one at home again till the next time off grid.
