secundinus
Aug 10, 2013Explorer
You may want to see if TAP Plastic's PolyWeld will help you out. I got great results in a black tank repair from it although it is a little more complicated to use. While I was down in the area, I also used Rustoelums Black Stop Leak spray to clean up the job visually -- and reinforce the job.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
