Peg_Leg
Aug 10, 2013Explorer
I had trouble getting things to stick to the ABS. I ended up sanding the area and using JB Weld and Plumbers Putty but I can't remember which one I put on first. Plumbers Putty is a two part epoxy that comes in a stick. You pinch off what you need and work it until the colors blend together. It can be applied under water.
I would try anything you decide to use on a area of a fitting to see how it sticks.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
