Lon-Str
Aug 10, 2013Explorer
My ten year old Montana developed a leak in the same place as pictured shortly after the warranty expired. After wire brushing and sanding the area with coarse sandpaper, I applied a coat of ABS cement around the area. After it had dried, I cut a one and one half inch strip of fiberglass cloth and after saturating it with cement, applied it all the way around the fitting. After it had dried I added a couple more coats.
That was many years and many, many miles ago, including two trips all over Canada and Alaska. It is still watertight today.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
