BFL13
May 01, 2015Explorer II
Seems like a good plan if the bedroom is up front and the batts are out front. The controller should be closer to the batts for less line loss, but be out of the rain, while it is less important to be close to the array up on the roof or wherever you have your array (portable out on the ground?)
#8 is a good gauge for array to controller in many cases, and could also be good for the controller to battery path depending on distance and expected amps on that path.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
