time2roll
May 01, 2015Nomad
TUCQUALA wrote:Your 150w panel is probably 18 Vmp and so when you lose 3 volts pushing 8 amps through that wire you will only be able to charge the battery at 15 volts.
According to the 12v wiring pdf from Outdoors RV, the wire from the 10W to the batts is 16 ga, don't think it would work for a much larger panel.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
