grizzzman
May 02, 2015Explorer
TUCQUALA wrote:
Just upgraded trailer to a new, much larger trailer (Timber Ridge 280RKS) which has a "huge" 10W Zamp solar panel. The panel is wired directly to the battery through a master switch and 30A breaker. It is not controlled by the disconnect sw.
Obviously, this panel is only for storage maintenance of the batteries, and a draw test shows almost .4 amps of draw on the batts from the many electronics in the trailer. These things are getting like cars with all the spiffy stuff!!
So, my plan is to add a 100-150 watt panel and parallel with the 10 watt. Think I can pull the wires down through the roof pass-thru that is installed and down through the front cap to the junction box under the front crossmember. Probably use 8 ga wire down to a PWM controller to be located in the bedroom and then to the batts.
Comments or condemnations??!!!
Gerry
PS: Can't edit my signature due to a long running problem with the preferences tab!!! Going on 5 weeks now, great IT around here!!!
I think using the 10 watt panel is a great idea. Cant have to many amps! I would suggest that you consider future upgrades. Perhaps pull #6 AGW wire. Then a combiner box up on the roof (I built one using cheap parts from home depot) and a 30 amp charge controller. That way when you find that you need more power (and its VERY likely you will) You can just add panels.
Good luck with your solar!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
