Hondavalk
Jan 20, 2016Explorer II
RJsfishin wrote:
Yes, I am amazed that my bypassing the switch is ok.
So in the other thread I got hammered for the black wire to be hot all the time,.......or was it just for switching the white instead of the black,..... and in this thread it is perfectly fine for the black to be hot all the time.
And in defense of some, and disagreement w/ others,....wives are not all the same. Mine has this mindset that if a lite is burning, it must be costing money,....wattage meaning nothing to her, and no explaining it either. So yes, in some cases I have to treat her like a kid,.....and its working :)
Thanks for all elect information, even tho IMO some of the codes defy common sense.
Yes the concern was only for switching the white (neutral) wire. Electricity is always ready to follow the easiest path to ground just as water wants to flow along the easiest path. With the neutral switched off there is a potential for you to become that path.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
