BigFly10
Jul 30, 2013Explorer
The inverter manual doesn't touch on this at all - it just says to connect the inverter ground to the trailer frame with a #8 cable.
I will try plugging the shore power into the inverter and see what happens......will need to open the breaker supplying the converter first but other than that it should work.
2oldman wrote:
I don't know.. does the inverter manual say anything about this?
Just for kicks try plugging your shore cord directly into the inverter (to power the entire coach, presumably) then see if MW works. I have the exact same inverter and never had this problem using my shore plug.
