BigFly10
Jul 31, 2013Explorer
I have the chassis ground running to a main grounding point at my converter, so I am not connected to inverter negative input but I am also not connecting straight to the frame as suggested in the manual.
I am starting to think this might have something to do with the problem. I am going to try going straight to the frame and see if it makes any difference.
BFL13 wrote:
My inverter's instructions make a big point to NEVER run the chassis ground lug wire over to the inverter's own neg input terminal (which goes back to the neg grounded battery) but run it straight to the frame.
Even though there is a path through the frame back through the battery (also frame grounded) the direct inverter frame ground seems to be ok under the rules.
I got lost in the OP :) but there may be a variation on this no-no there.
The purpose of the inverter's chassis to frame wire grounding is to reduce radio and TV interference. The inverter will run just fine without the chassis ground being connected.
An intermittent GFCI issue may be due to a loose connection somewhere?
