shooted
Aug 12, 2013Explorer
Can you provide a wiring diagram of your installation? It appears to be a problem isolated to the sub panel or ATS.
Edit, on second thought, the problem is probably at the ATS, or between the ATS and inverter. I would verify wiring at the ATS paying special attention to proper/correct connection from the inverter. I suspect a wire assembly defect between ATS and inverter.
