Bobbo
Nov 13, 2018Explorer III
Tom_M wrote:
Your converter will apply 14.4 volts during boost, but your battery will pull that voltage down. As the battery charges the voltage will gradually ramp up. It should at some point reach 14.4 volts and continue charging until 90% charge has been reached.
This ^^^^^^^^^^^^^^^.
It took me a while to figure this out. I have a solar controller with a panel on the wall. The panel gives the amount of charge at the battery. When I had a 50% SOC battery, and plugged in, my PD4645V converter/charger was SUPPOSED to go into 14.4v boost mode. My monitor showed about 13.5v or 13.6v. Over a period of about 4 hours +/-, the voltage would creep up to 14.4v, slowly. Finally, I got a DVM out and checked the voltage at the converter/charger. It was 14.4v there all the time. It was only at the batteries that I was seeing less. The converter/charger was doing its thing, and the batteries pulled the charge down, until they finally get enough charge.
Let me give you an analogy. You have tires that need 80psi, but you only have 40psi in them. You get out your trusty air compressor with 125psi of pressure in the tank. You start airing up your tires. Your tire pressure doesn't jump to 125psi as soon as you connect the air hose. The tire pressure slowly rises from the 40psi to whatever you allow in over time.
The exact same thing is happening to your battery. You have 11.5v in the battery and hook up a 14.4v charger. The battery's charge, over time, rises from the 11.5v to 14.4v, slowly.
Having RV issues? Connect with others who have been in your shoes.24,395 PostsLatest Activity: Jun 23, 2026
