Bobbo
Nov 13, 2018Explorer III
MEXICOWANDERER wrote:
This is losing contact with reality as far as GENERATOR run time. With shore power, who cares?
If I walk out to my toad and start it the much touted BOOST (or is it BOOOST?) voltage appears. Regulator alternator charging voltage. Does the charging system on the car sag to "regular" charging voltage of 13.6? Hell no.
Tens of thousands of RV batteries are destroyed every year because boondockers believe that converter manufacturers specify is gospel
What's gospel about their mantra is that they cannot be sued for purposely overcharging a battery.
This reminds me of California's banning of battery CHARGERS in favor of socialist inspired government mandate to undercharge batteries and a (what?) thirty or forty times charger failure rate (landfill) as being environmentally preferable. Oooooo a timer on the charger who wudda thought of that.
The only way to achieve rational battery life when BOONDOCKING is to know for sure the battery state-of-charge.
A 20-amps per 100 amp hour bank, solar system with a good grade of solar controller seems to be the only antidote to the fallacy of smart chargers via generator WHEN BOONDOCKING.
Mex, it is MY thread that is about charging with a generator, and I really appreciate your input. Between you and BFL13, I think I finally understand the answer. On mine, upping my charger from 45 amp to 55 amp might (maybe) shave about 20 minutes off of my 4 hour charge time.
This thread, the OP is just wondering why he is not seeing the 14.4v at the battery when he STARTS charging.
Having RV issues? Connect with others who have been in your shoes.24,395 PostsLatest Activity: Jun 23, 2026
