Bobbo
Nov 14, 2018Explorer III
rtate wrote:
Can I expect my t105s to go from 11v to 90% charge in a couple of hours?
I think a couple of hours is extremely optimistic. I think 4 hours is a safer bet.
BFL13 wrote:
T-105s or any other battery should not be down to 11 volts! 50% is 12.1 volts.
A pair at 225 AH at 50% with a 45amp charger doing constant 45 will take about 85 minutes to get the batts to 75% , another 20 min to 80%, and another hour from 80-90. So total 50-90 will take about 3.4 hours. the 80-90 for an hour might not be worth the gen time, which is why many do 50-80s instead.
BFL13 is right on the money here. My batteries are a little smaller than 225 AH, but my wiring is a little smaller too. My 158 AH battery bank at 12.0v or 12.1v (50% SOC) takes right at 4 hours charging time over the 6g wire. I don't really know the final SOC, but I consider it done when the PD4645V drops its charge voltage from 14.4v to 13.6v. I call it 90% SOC, but that is an assumption on my part. I have never let it charge to that point then let the surface charge go to get a reading.
BTW, I am the OP on the other thread, the one where I was trying to decide if I wanted to upgrade from a 45 amp charger to a 55 amp charger. The solution was no. It would only save me about 20 minutes charge time, at best.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
