MrWizard
Nov 16, 2017Moderator
buy the screw terminal outlets, don't use push in outlets with stranded wire
even with romex solid gauge wire, the push in type come loose in an RV
i assume you mean 3-wire, outdoor type extension cord, NOT 2-wire zip cord, that some people might be thinking about
good outdoor cord is very rugged and NOT going to dry out and crack
just anchor/clamp it good, and should not have any problems
put a rubber grommet/bushing where it passes thru metal surfaces
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
