ryde2rope1's avatar
ryde2rope1
Another Slide out Question
I know there have been many questions on Slide outs not working but I could not find one that addressed my issue. I am a full timer so slide out stays out for long periods of time. I have to move it and the slide out will not move. I press the power button and the lights will dim in RV but the slide will not move. I tried using the hand crank but it will not move it either. I am a retired female and am not sure what or where to start looking to troubleshoot this issue. Any help would be appreciated. Thank you.
  • Listen,....... She said it won't move manually. And this is coming from a probably tough ole gal. So if she can't move it, the battery probably can't either. :)
  • Can also be a bad ground connection. My 2002 Sun line had a ground cable. It came loose and the slide wouldn't operate. Once it was reattached, problem solved.
  • one our one slide even if you run it in or out manually some one still needs to hold the manual override button. It has a lock on it to stop any movement. So you still would need two people and 12 volt power for it to work.
  • Sounds like slide out is binding.......using hand crank try to extend it a little bit then try to retract.
    Slide outs are typically wired directly to battery with their own in-line fuse or dc circuit breaker.......so a fully charged battery is needed even when plugged into shore power
  • Slides are dependent on the battery even when plugged in to electric. The hand crank is often very hard to turn, especially after sitting a while.
  • THe RV is plugged in to electric . Would it still be using the battery? If that be the case then why won't the hand crank work either. It will not budge in either direction.
  • Marti - what type of RV are you talking about? Might help more INFO needed. JMO
  • I press the power button and the lights will dim in RV .
    sounds like a dead battery and / or converter not charging
    good luck, someone will answer.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 07, 2025
