TexasVet01
Feb 11, 2014Explorer
I use an AC fusible disconnect box. Wire the positive from the PV panels to one side. Then wire the positive from the charge controller (to the batteries) to the 2nd side.
All you need to do is pull the disconnect to remove both fuses and isolate the controller from the PV's and the batteries.
Don't forget the use a 300 amp fuse between the batteries and the inverter.
Happy Trails,
Lew
Happy Trails,
Lew
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
