brulaz wrote:
. 6ga down to trailer pass-thru where it joins up with a PD9260 charger with convenient double bus. Then down and out to batteries on the trailer tongue.
(This is strictly a battery charging circuit, solar or 110V; there are no external loads. The original WFCO remains as the converter.)
I'm not quite sure what you mean here. The solar, converter and batteries connect to a common point so of course there are external loads. The fact that you may not have any load connections in the segment between the converter and the batteries does not change thIs.
Looks like a very nice install. You'll be happy with the Rogue.
