ktmrfs's avatar
ktmrfs
Explorer III
Oct 16, 2013
Answering some solar panel with MPPT controller ?
Here is some real world data on solar panels when used with a MPPT controller to answer some question I, BFL and others have.
This report is focused on the questions we had regarding solar panel use with MPPT controllers.
AND FOR THOSE WHO MAY WANT TO START A MPPT VS. PWM CONTROLLER DISCUSSION PLEASE DO NOT TURN THIS INTO ANOTHER MPPT VS. PWM DISCUSSION, FLAME ETC. IF YOU WANT TO CUSS OR DISCUSS PWM VS. MPPT CONTROLLERS GO START ANOTHER THREAD.
OK, now to the questions I was looking to answer for:
1)BFL’s question; “Can you look for a peak in Voc or Isc to determine optimum panel orientation?”
2)Can one predict accurately output power by measuring MPPT input voltage and panel output current?
3)In late fall at high latitudes what % of nominal power can I expect to get from the panel under optimal light?
4)Can one predict power loss between the panel and controller and predict the effect on output power (charging current and watts) with reasonable accuracy?
5)If one knows the resistance and current between the panel and controller can one predict the power to the battery with Series vs. parallel panels and longer or higher resistance paths between the panel and controller? (really an expansion of the above question)
6)Can one measure Temperature effects on Panel output power?
7)What is typical MPPT controller efficiency, or for this paper, the efficiency of a Morningstar sunsaver 15 MPPT controller operating in the 130 W region???
8)What if I just lay the panels flat, how far from peak power will I be?
9)With series connected panels what is the effect of shading on one of the panels?
10)Since I also have another trailer with PWM controller and use the same portable panels with this trailer, I was curious what effect a long (90ft) run between the panels and PWM controller has when used with a PWM controller. In this case I don’t have the choice of going series connected panels, that’s counterproductive. So staying with parallel connected panels is the only choice. Can I predict the results?
Rather than one LONG……. Post, I will break the post into sections. The next section is focused on assumptions, test conditions, test equipment, and test methodologies.
Then there are individual posts for each of the 10 questions.
And for those reading now, please delay any responses till you see a “That’s All folks” in my last post so my posts can be in sequence uninterrupted. I should have them all posted within an hour.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
