westend
Oct 16, 2013Explorer
Thanks for your experiments and posting. I know this took quite a bit of time and was more for the benefit of others.
I'll try to get up some type of meaningful numbers with my own smallish stationary system when time allows. I have the SS-MPPT-15 and Morningstar communications adaptor so, if I can get an understanding of MSView, the data should be easier to log and display.
Reading between the lines of how you use solar and your usage, along with the equipment you have, it seems like the purchase of a bigger +200w panel might fill in your power requirements quite well. I guess that would depend on how many modules you want to deploy and if you deem it worth the effort and expense.
Thanks, again for your efforts, there is very little real world data that is at the level of what you've done, and available.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
