ktmrfs
Oct 17, 2013Explorer III
CA Traveler wrote:
The serial panel shading test could suggest that the panels have bypass diodes. Is that the case? Shading only 1 or 2 bypass cell areas would also be interesting.
Perhaps even more interesting would be a test with soft shading (like a tree) on 1 and 2 panels as compared to full sun. Past discussions suggest parallel panels with soft shading on one panel will outperform the same shading on serial panels. I.e. Soft shading on one serial panel restricts the output of both serial panels.
More ideas for more tests. And if I do more tests, I think I'll just use the MS SW for the controller.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
