solismaris's avatar
solismaris
antenna broke, recommend replacement?
My tv antenna broke and it's time to replace it. It was the old-style rotating kind with a crank to raise and lower i, with the long horizontal bar elements (Winegard?) Looked like this (before it broke):
http://www.solidsignal.com/pview.asp?p=rv3095&d=winegard-rv3095-sensar-iii-amplified-directional-rv-tv-antenna-manually-operated-%28rv3095%29&utm_campaign=base&utm_medium=organic&utm_source=google_base
My question is, what do I replace it with? Recommendations? I'm thinking that now with the switch to digital (and all on the UHF band now) there are no longer any VHF signals to receive, so the large size isn't needed. Is there a new style that is designed specifically for the new digital UHF signals?
(Yes there is - I found lots on my web search, but was overwhelmed. I do want rotating, not omnidirectional. I found some but they seemed to be a fixed height above the roof and don't lower. I'd worry about snagging a tree branch if it can't be lowered.)
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
