pinesman's avatar
pinesman
antenna lube
I have the regular batwing tv antenna on my trailer and it is hard to raise and lower. There does not appear to be anything bent so I am thinking it is just dry. What kind of lube can I use that will not mess up the rubber roof if it drips?
  • Thanks for the replies. Silicone is the answer that I was looking for.
  • shastagary wrote:
    read page 5 about lubrication LUBRICATION
    And pay attention to lubricating the rubber quad ring. Otherwise your antenna may leak water into your rv.
  • lots2seeinmyrv wrote:
    On our previous trailer...there is a small "eraser" head sized plug on the base on top of the roof.
    Carefully remove it, spray silicone spray in there, move the antenna around and see if that helps.
    And spray the lifting gears as well. If it moves, lube it.
  • On our previous trailer...there is a small "eraser" head sized plug on the base on top of the roof.
Having RV issues? Connect with others who have been in your shoes.24,352 PostsLatest Activity: Jan 21, 2026
