Lynnmor
Jun 10, 2018Explorer II
wayne1234 wrote:
Can anyone tell me a simple way to check that the antenna is working, the cable from the antenna is ok and how I would check the power source.
To answer your question, disconnect the cable from the antenna, there should be 12 volts between the center conductor and the outside of the connector with the switch and light on. Be careful that you don't short the center to outside.
After verifying that you have power to the antenna amplifier, you can continue to other areas if necessary.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
