George3037
Jun 10, 2018Explorer
wayne1234 wrote:
Thanks to everyone for your replies. To answer a few of the responses.
While in Florida I had digital tv. When I left my first stop was Savannah Ga. I had digital tv. My next stop was Myrtle Beach, no digital tv. The next stop was Gettysburg Pa. no digital tv. My question is what happened after I left Savannah and could not get digital tv. Is there an easy way to check and the one person who suggested a cable break, I will check that ASAP.
Thank you to all,
Wayne
PS how do I check the power system?
It was mentioned before but as you traveled from state to state did you go into the TV menu and re-scan for channels or are you just trying the same channels you received in the last state? Each state may broadcast over the air channels on a different frequency. If you did re-scan then I'd suspect a coax or antenna problem also previously mentioned.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
