pulsar
Oct 04, 2017Explorer
roadrat57 wrote:
Thanks to all of you. My rig does have plumbing for pumping anti-freeze into all the lines as well as a bi-pass for the hot h2o tank. I don't understand why the manual would recommend dumping anti-freeze into FW tank???
I took your original post to question why the owner's manual says put 5 gallons of antifreeze in the fresh water tank.
In the winterizing instructions in the Fiesta owner's manual I have, one is directed to introduce the the antifreeze into the water lines using the water pump to pump the antifreeze out of the fresh water tank. No where does it discuss a winterizing kit (valve).
(See instructions 15 through 18.)
What does your owner's manual say to do with the antifreeze you've put in the fresh water tank?
Since you have a winterizing kit, use it and don't worry about the fresh water tank, after you have drained it.
Tom
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
