roadrat57 wrote:
My manual says to add 5 gallons of non-toxic antifreeze to fresh water tank. I have not seen or heard of this. I thought draining tank would be sufficient for winterization. My current knowledge is to never but anything in fresh water tank other than fresh water or fresh water and chlorine to sanitize/
For your rig, 2000 Fleetwood Fiesta LX, the only way the manufacturer provided for getting antifreeze into the water lines is through the fresh water tank.
I would not put antifreeze in the fresh water tank for reasons others expressed, above. If blowing out the lines leaves you worried, then you should consider a third party winterizing kit. Such kits are easy to install and allow one to use the rev's water pump to pump antifreeze into the plumbing system without using the fresh water tank.
Do a search for "rv winterizing kits." Camco makes one that sells for around $12.
Tom
