BaddogLT's avatar
BaddogLT
Any glaring flaws with this battery and system upgrade?
After having to take last year and this spring and summer off, want to do a couple of dry camping trips this fall - No. CA and NV, So. OR.
Currently have the 84 AH Group 24 the used RV dealer put in. Have had issues in the past with the heater fan draining the battery too far when fall camping (and, as a result, the battery is probably shot).
We do not have and won't be getting an inverter. Fridge is 2 way so no 12V there. We're changing interior lights over to LED as they blow.
Decided on two Lifeline GPL-4CT 6V batteries (220 AH).
Leaning towards AM Solar's budget setup for 210 watts (105 x 2). Will be mounting flat.
Also leaning towards a Victron monitor over the TriMetric. Mainly because it comes with shunt and cables making it effectively cheaper, partly because it does not look like something I made in HS electronics.
Not planning on a generator unless we decide to use AC some season down the road.
So, anything glaringly wrong with this path? Any suggestions?
First investment in the trailer since buying it in 2008!
-CJ
Having RV issues? Connect with others who have been in your shoes.24,334 PostsLatest Activity: Nov 09, 2025
