nowgrn4
Dec 26, 2014Explorer
Your Yammy 3000 has smart throttle and boost technology. You could easily run the 7,000BTU A/C with it. I would start the A/C on the gennys regular setting Then crank the A/C to its coldest setting so the compressor never cycles. Then reduce the genny to smart throttle and get the lowest fuel usage available. If it gets too cold inside, crack a window.
