ctilsie242
Mar 24, 2017Explorer II
I have one of those, and it is discontinued. The EF3000SEB is almost identical, except it has the ability to use the battery "boost".
Toaster + Coffeemaker + converter will work. AC + microwave will not. Running a 13.5 or 15k AC depends on model and if there is a hard start cap on the A/C. I've found the trick is to start the generator, nuke something for 30 seconds, then flip the A/C on, and it should do the job.
That generator is pretty decent. I had over 3500+ hours on mine until it seized, and I'm pretty sure the fix is going to be fairly simple.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
