- mena661Explorer
BroncosFan wrote:
X2, great read!
Rmcgrath53,
Just google technomadia lithium
Almot, you would DECREASE the battery bank size with LI not increase because they can go lower in SOC. Some say 90% DOD but others say 80% DOD gets more cycle life. I would go no further than 80% but your BMS would prevent accidental overdischarges anyways.smkettner wrote:
Thanks for the link. I read that as long as they don't self discharge into the dead battery zone, they're fine. I also read not to charge to 100% cause it's tricky getting there. 97% is easier.
My resources say store Li-ion closer to 30% to 50%. For long life you don't even go 100%. If you charge near max the energy should be used shortly. Keep them cool. Verify with manufacturer as there are many sub-chemistries in Li batteries.
This from electric vehicle best practices.
Found this reading:
http://www.roguepowertech.com/documents/ChargingLiIon.pdf - BroncosFanExplorerRmcgrath53,
Just google technomadia lithium - AlmotExplorer IIIThe need to change the controller settings is a huge drawback indeed :). Probably takes whole 5 or 10 minutes, including reading the manual. That is - if your controller allows such an adjusting, because basic low-cost units often won't let you disable the Float and temp compensation.
Marc at Rogue knows his stuff. I only think that there is less than 3 times price difference between AGM and flooded. Unless you buy Lifeline, it's more like 30-40% difference.
Li - don't know, AGM was a purchase big enough for me. Not looking forward to spending few times more and/or increase the bank due to higher charge density of Li. My solar keeps AGM bank of 300 AH full every day.
Where Marc says about optional dataport that is needed to change the settings - this is only for their 20A model MPPT 2024. 30A model MPPT 3048 is programmed right on the box, as it should. Just push the buttons. - My resources say store Li-ion closer to 30% to 50%. For long life you don't even go 100%. If you charge near max the energy should be used shortly. Keep them cool. Verify with manufacturer as there are many sub-chemistries in Li batteries.
Found this reading:
http://www.roguepowertech.com/documents/ChargingLiIon.pdf - mena661ExplorerNo float. You don't float LI batts. Just charge them up and leave them disconnected. Hopefully your battery management system (BMS) auto-disconnects the charging source when they're full (another advantage). Also, they don't need to be fully charged when stored either. As long as they stay above 90% DOD, they're good (they still self discharge but at a rate less than or about the same as AGMs).
- Rmcgrath53ExplorerI was wondering what are the advantage of lithium over lead beside price.. 1) discharge way longer, 2) recharge much faster 3)way less weight. 4) last 10 time longer. Disadvantages are 1) price is very expensive compared to lead batteries.2) have to reprogram your controller.3) Smart battery is prone to go bad in EMP detonation , along with your solar panel may fry during an advent like that.
EsoxLucius wrote:
Reed Cundiff
Thanx for the site. - MEXICOWANDERERExplorerIMHO you need to talk with someone with a direct link to OEM engineering. Not just an applications engineer (educated salesman) but a genuine engineer. Note I said link and direct. If a battery manufacturer is responsible they will provide comprehensible information as to the charging protocol. Something you can understand and relate to. Be prepared to ask for their published information regarding care and maintenance of their product. I somehow doubt you will run into a snag on your quest. Good luck.
- EsoxLuciusExplorerReed Cundiff
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
