rottidawg's avatar
rottidawg
Any problem in using two battery maintainers at once?
Updating a previous thread:
I have a 2012 Chevy truck with a 2012 Four Wheel slide in camper. The camper is equipped with a Iota DSL30 converter and I recently added a Iota IQ4 battery plug in smart charger to it. Works great at keeping my two camper AGM batteries charged.
I also want to keep my truck battery charged. I have a Battery Tender Plus that I use on the truck starting battery. My question is, do you see any problems in using the two charging systems together?
I know that when using the Battery Tender Plus on the truck battery that it also sends a charge to the camper batteries, although not very effectively. Because of the battery separator, the Iota can not charge the truck battery, correct?
Do you see any issues in charging with both the camper/iota and truck/Battery Tender Plus at the same time, i.e.: camper batteries getting charged by both chargers?
  • Not sure about the actual correct answer, but first--can't you just unplug the camper from the truck? You aren't driving at the time you want to do this.
Having RV issues? Connect with others who have been in your shoes.24,296 PostsLatest Activity: Aug 06, 2025
