Naio
Apr 30, 2017Explorer II
Yeah, the fan I was going to use is ac, only on when inverter is on. I can also open the cabinet door when in use.
Yes. The inverter shuts down from overheating. When running 65 watts output for 20 minutes at 26 degrees. It is wimpy.
No, I am not foolish enought b to drill into the case without removing it from the inverter first. Sheesh!
Hmm mm mm mm, sounds like I better test out the fan on msw power before installing it permanently!
I will be soldering things, despite my previous post. I want on/off switches for inverter and fan by the bed. On cold boondocking nights I like to goose the electric mattress warmer once in a while, but not leave the inverter on all night.
I'm going to end up with a MASSIVE switch panel next to the bed! Inverter, fan, lights... Thinking to use toggle switches. Gonna look like appollo 13 in there.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
