Naio
Apr 30, 2017Explorer II
time2roll wrote:Naio wrote:I know you said you are broke but so is this inverter.
Yes. The inverter shuts down from overheating. When running 65 watts output for 20 minutes at 26 degrees. It is wimpy.
Not worth installing IMO. I assume no phantom hidden loads because 65 watts is not much power and only 10 percent of rating.
Yeah, it is cr*p. And erratic. Sometimes it will run hundreds of watts and sometimes it won't run a heating pad (I think those are 15w?).
I thought it was me until Mex said he had the same experience with HF inverters.
Like I said, I don't need it often. Although I might want it more when I get my new (used) massive battery bank.
I do have an antique metal 300w Tripp-lite I got at a garage sale for $2, untested because of broken plug, in my projects pile. I expect I'll install both of them unless that one doesn't work.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
