pianotuna
Oct 27, 2016Nomad III
Go with what is purple and hums (i.e. the Grape controller)
Run from the battery not the controller.
marininn wrote:
Thanks, good info. I can see myself adding two more panels, for 400 watts, but probably never go higher.
I want to run the coach off the controller terminals, but I like running directly off the battery so I can use shorter runs and use larger wire.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
