marininn's avatar
marininn
Any Solar EXPERTS? charge controller
I have had it with the cheap china $30 or $15 solar controllers. They do move voltage, but never seem to work the way they are advertised. And that tiny screw that only works with phone wire is not what I want when I am using heavy gauge wire.
I am looking at the Morningstar units, for about ten times the price though.
Is this a good choice?
I have two 100 watt panels on the roof, and two 6 volt golf batteries in series for 12v.
The solar charges the batteries and I run off the batteries.
I also have power from the tow vehicle when driving, but this is not a heavy gauge wire, and it is hooked to the battery and not through a controller.
I would like everything to be controlled (tv power, solar power, converter power, and outgoing power).
I would like power cut off before I drain a battery dead.
What are the best, and most price conscious options?
Hoping to hear from those who KNOW rather than opinions too. thanks
  • I have a Tristar MPPT-60. Excellent controller and performs exactly as expected. Very flexible programming. Probably a bit much for 200 watts. There is a 30 amp version but I think you want a PWM controller.
    You need to use the load control circuit if you want to use the controller to cut power before the battery becomes overly discharged. Only issue is these circuits have a limited amp rating that you need to stay inside. Could protect with a fuse or breaker but that could be a pain in the neck also.
    Would an alarm work? Then you would have to cut power or charge the battery manually.
    search 'voltminder' (amazon)
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Nov 27, 2025
