Community Alumni
Feb 22, 2025Not applicable
Any way to burn off onboard propane outside?
Any way to burn off RV propane outside? I will need to burn off may be 3-4 gallons of propane to get my onboard tank empty and cant do it inside as it will be getting hot by then. My onboard tank has quick disconnect port outside, but it provides low pressure propane, so none of my outdoor appliances would work with it, as they are high pressure. Not in a position to buy a new low pressure appliance as they are bulky and expensive. Do not have accesss to propane shop that got equipment to flare it all iff for me neither can do modifications to whats installed on RV tank now. So far I gathered I can drill to enlarge burner holes in a standard high pressure camping stove, to make it work with low pressure. Are there any other ideas?
