lawrosa
Jan 17, 2018Explorer
Youll need to test some more to determine. Remove the pos/neg leads from battery and see what volts you get from those two leads..
I dont think you have a bulk mode. just 13.6 volts and a float mode as it sits now..
https://www.iotaengineering.com/pplib/IQ4_no-DV_hookup.pdf
I found this link to an old ILC iota load center..
For giggles , what is your actual load center model #.
I like to look up and post documents so when others come here searching for answers they will find all the info they need.
Per this maybe you dont have anyway to make it 4 stage.
But also if you let use know what you actually have we can find a unit that will fit in the space..
Actually I think you may have the load center in the link below. And if so there is no drop in replacement for that .
I think you may need to mount the new charger behind it somehow or get a new load center...
http://www.gulfstreamcoach.com/media/uploads/1/11618_IOTA-Load-Center-Manual.pdf
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
