- MEXICOWANDERERExplorerA good termination eliminates liquid, air, high resistance, and STRAIN RELIEF, notice the multiple characteristics.
- T18skyguyExplorer
Teamfour wrote:
If you don't need waterproof connectors these work real well. If a permanent waterproof connection is needed I drip a little liquid tape in the ends.
Link
Yes Posilocks are great. I met and talked to the owner/inventor of the company. Very nice guy. He said the hardest part of getting the business off the ground is people don't know what it is, since it's a new idea. He went on to say that if you want to succeed fast, improve an existing product instead. - MEXICOWANDERERExplorerAnyone? That's potent overall coverage advice :)
- Cummins12V98Explorer IIIJust the simple crimp and shrink connectors are more than anyone needs for a RV. That's what I use on my Boat.
- MEXICOWANDERERExplorerWhen they add BISMUTH to Pb and Sn melt temperature drops by a hundred degrees. That's the magic formula.
- theoldwizard1Explorer IIYes, they look interesting, but I can not find refills for specific sizes.
I think I would buy their crimp with shrink tube set instead. Large selection of various type of terminals.
Or of you just want butt splices.
- JOHNZExplorerWhen you soldier stranded wire the solder wicks up the strands and males them stiff and brittle. Then under vibrating condititions they have a greater tendency to break.
- GordonThreeExplorerCold soldered butt joint? How much force required to break the joint, more or less than a double crimped butt joint?
- wa8yxmExplorer IIIHave not tried them MYSELF but... There is an internet TV show. Ham Nation. and a second one the url is amateurlogic.TV both feature one of the same "Stars" George Thomas. He does the "Smoke and solder" section on Ham Nation.
I Think it was on Ham Nation he reviewed those connectors. They worked. But he questioned how strong the joint was physically.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
